condensate pump
Old 09-23-02, 05:58 PM
ann peterson
condensate pump
I have pvc pipe to drain the excess water from the humidifier and air conditioner, it runs all the way around the room, about 25 feet. I have heard of a small pump that I can direct the water into, pump it up and over to the utility sink. What is the pump called and where can I purchase one? It seems like it would be easy to do.
Old 09-23-02, 07:22 PM
hvac4u's Avatar
condensate removal pump
avaialable at home improvement stores. typically 115 volt plug in, and 3/8" ID vinyl tubing fitting out. they are rated for the height you want to pump, 20 foot "head" is typical for most applications. tubing is usually extra.
