heat pump
Old 10-15-02, 04:36 PM
Bud2
heat pump
I have a heat pump.....live in Florida...........yesterday I noticed the fans outside were running, but there was no cool air into the house........seemed like no air at all. I jogged the thermostat lower, but it didn't change, shut it off anf turned it back on a few times, but didn't hear the usual noises that it makes when I turn it on. Any hints Sempter Fi?
Bud2
Old 10-15-02, 05:02 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
no cool
You would have to go and check in the unit more outside.Is the compressor running or not.I mean there can be a lot of things here why you dont have cool.Was the fan inside running?From what you ask i think you should call a HVAC man ED
Old 10-15-02, 06:41 PM
hvac4u's Avatar
more details needed
semper fi, bud, give us a few details. sounds like the outdoor unit is running without the indoor unit on? or is it on but no airflow? does the outdoor unit cut off when tstat if off? does fan run in on position? let us know,
