No heat from downstairs radiators
Old 10-20-02, 03:40 AM
gordonkayuk
my downstair gas central heating radiators do not heat ihave bled radiators pump seems fine boiler ok i have changed valves any ideas cheers
Old 10-20-02, 11:06 AM
R
Radiators sometimes get a stubborn pocket of air in them and will cause the problem you're experiencing. When bleeding the radiators, try tapping the radiator slightly to jar this pocket of air loose.
Your description doesn't tell me if there are separate thermostats for the downstair and upstairs. If they are, it could be a zoning valve and/or this zone is air bound. In either case this is not a job for the do it yourselfer. You're better off calling a qualified service person.
