Chimney liner
Old 10-24-02, 01:01 AM
Chimney liner
OK I'm helping out the gas guys and I said that I would install the chimney vent. It is the hefty steel colapsable stuff that looks like dryer vent tube. The instructions are a little vauge on how to connect the tubing to the top collar. It came with metal screws and these wierd rivets that I have never seen. It sayst to rivet the tube to the collar but I dont know how to work the rivets and I dont have a rivet gun or whatever. will the screws work just as well?
Old 10-24-02, 04:29 PM
Ed Imeduc's Avatar
flue
I go get a good rivet gun and put them in.Or you can get some SST screws and nuts and use them . I dont think I would just use the sheet metal screws to hold it up ED
Old 10-24-02, 06:06 PM
hvac4u's Avatar
flue liner
have installed manyof these, definately use what they give you or stainless screws, as regular zinc coated will eventually give way, and liner will fall.
