Mildew Smell From Ducting
Old 10-24-02, 08:15 AM
Billie Faye
Mildew smell coming from heat ducts
Model DAYH-F024N070C
S# NDGM050510
located at the north side of home.
Forced air furnace/cooling
Natural gas
We just had the furnace replaced about 3 years ago. A relative did the work and we did not have the duct system replaced. Now we have a mildew smell that comes up from the vents. It can be pretty strong at times. We noticed it the frist time we used the heater and I think also the first time we used the AC. So I am pretty sure it is coming from the ducts. Don't have alot of money and would like to know if this can be fixed as a do-it-yourself project?
Old 10-24-02, 03:43 PM
lynn comstock
Clean your cooling coil.
A dirty cooling coil is a breeding ground for mold and mildew. Clean it and the smell will probably go away. Then be fussy about your filters from now on to keep it clean.
Old 10-29-02, 12:30 PM
Billie Faye
Mildew in heat ducts
Thanks for your help. The problem seems to be solved. We do not seem to smell the mildew any longer. This is a very good program to have for people. Thanks again! Billie Faye
