Themocouple Replacement
Old 10-27-02, 09:33 AM
Kevin_N_Phoenix
Question Themocouple Replacement
I have a Colemen model 7670 natural gas furnace, in a mobile home. I'm not sure of the year, but it is believed to be in the mid-70's.
I need to replace the thermocouple, but for the life of me cannot see how to remove it.
Does anyone know of a website that I can look for a schematic?
I know it doesn't get very cold here in Phoenix, but HELP it may hit 50 tonight!! lol
I'd appreciate any help anyone may have to offer.
Old 10-27-02, 11:58 AM
bigjohn
Which end are you refering to? At the pilot burner they usually just slide out and at the gas valve there should be a small nut which you unthread with a wrench.
Old 10-27-02, 12:04 PM
hvac4u's Avatar
i hate those
units. need a couple of 4 inch tall guys for the job.
Old 10-27-02, 01:02 PM
Kevin_N_Phoenix
Thanks
I got it out and replaced, but didn't seem to be the problem. It has a new thermostst and thermocouple, pilot light stays lit, but furnace wont kick in.
What other possibilities...the regulator?
Old 10-27-02, 01:30 PM
54regcab's Avatar
Question 24vac
Do you have 24 volts ac across the valve ??
I'll bet there is some type of wiring problem
Old 10-27-02, 01:40 PM
Kevin_N_Phoenix
Thanks Jul
I cant find my electrical tester, may have to runout to picl one up. Your referencing testing across the ignition module? I erroneously refered to it as the regulator earlier.
Old 10-27-02, 01:48 PM
54regcab's Avatar
Lightbulb Gas valve
The gas valve is the control where you light the pilot, it should have 2 wires going to it.
24 volts AC turns the gas on to the main burners.
If you aren't getting 24vac on the valve you will need to troubleshoot the wiring or call a pro
Old 10-27-02, 01:50 PM
Kevin_N_Phoenix
Thanks Again
Thanks for all the help...I will check it out.
