oil furnace not circulating to radiators
Old 11-05-02, 10:28 AM
B
BillieC
We have a oil furnace with radiator heat. We have a problem with the radiators not getting warm or hot. We bled all the radiators and got steady water, the circulator seems to be working properly, and we drained the "overfill" tank, it was heating then stopped. Any help with this problem would be helpful. The burner is working fine the furnace does come on when thermostat drops to that point but if we cut thermostat it takes rather a long time to cut off.
Old 11-05-02, 08:02 PM
P
purger406
when you bleed the rads make sure that you are adding water to the system as needed try not to exceed 12 -18 lbs ...varys with height of building
