A/C Condensation Question
Old 11-11-02, 04:57 PM
sonygp
Plugged drain on air conditioner condesate piping
We live in Louisiana and of course it is always humid. Our condensate piping seems to be plugged. We have plastic piping. What is a safe, home remedy we can pour down the drain to unplugged piping?
Old 11-11-02, 05:39 PM
Nominal
Have not had any luck with pouring in anything to unclogged drains. However, If you have a wet-vac, and you know where the drain line exits the house outside, use wet-vac and suck all of the slime out.
Old 11-12-02, 09:55 PM
GregH's Avatar
Super Moderator
Received 18 Votes on 18 Posts
sonygp:
Normally the piping from the cooling coil drops into an open drain.
Is it the pipe near the cooling coil that is plugged or the house drain?
Old 11-13-02, 05:46 PM
Ed Imeduc's Avatar
drain
You might not like this but most of the time just try and blow back in the drain line . The end away from the unit-------and look out. Works most of the time . Then HD has some pills you can drop,in at the coil. ED
Old 11-13-02, 07:57 PM
hvac4u's Avatar
ED is right
pouring bleach, etc is a quick fix, those "pan tabs" as we call them are good a steadily producing flow of bacteria/algae eating chemicals.
Old 11-14-02, 07:41 PM
Jarredsdad's Avatar
Yup
All good advice.
Once it's unclogged, a cup of bleach and 1/2 gallon water every 6 months is the way to go.
