Forced air furnace problem
Old 11-18-02, 08:41 AM
bigv36b
I have a Rheem model #RGDE-07EMAGR forced air furnace with a honeywell class2 LR1620 30v. Thermostat. My problem is this- when heat is called for, Exhaust fan comes on, burner ignites, main fan comes on. All which is normal. After 2 mins of operation- the burner shuts off, leaving the main fan running for 1min and the exhaust fan stays running unless turned off manually. The unit is 11 years old with no major problems other than changing the igniter about a year ago. Please Help?
Old 11-18-02, 06:51 PM
hvac4u's Avatar
sounds like the
unit is starving for air, and high limit taking it out. check filter, blower wheel and coil for blockage.
Old 11-19-02, 05:47 AM
bigv36b
problem solved
You hit the nail right smack on the head. Found outside exhaust door dampner stuck closed. Will give unit a good cleaning. Thanks for the help.
