str8 cool elect heat, need help
Old 11-18-02, 03:41 PM
charlie856
Question str8 cool elect heat, need help
hi an thank you for any help you can give me,,,,i have an amanda spilt system, i put in a new t stat an i'm getting cooling but when i put it to heat it trips the breaker, now there is a jumper wire that goes from rc to rh, do i need to leave it there or take it out, with the jumper wire in place the heat comes on then trips the breaker in less than 2 sec, i tried changing both relays an the sequester, but it still trips, i also checked the heat strip an its good, am i doing something wrong? i think maybe it could be the breaker? can someone help me with this,,,,,thank you, again charlie,,,,,,,,,
Old 11-18-02, 04:44 PM
hvac4u's Avatar
no heat
may be breaker, leave rc and rh jumped unless there is a transformer outside at the a/c. if this is a mobile home, probably has one. 2 transformers with jumper in will not trip circuit breaker. will blow low volt fuse or burn out transformer. can you check amp draw at breaker?
Old 11-18-02, 06:34 PM
charlie856
yes i can check the amps at the breaker but what amps am i looking for?,,,the breaker says 45 on it, also the heat strip is a 7.5 kw, i will check it in the morning,,thanks again
Old 11-18-02, 09:27 PM
GregH's Avatar
Super Moderator
Received 8 Votes on 8 Posts
charlie856:
To diagnose this problem you need a clamp on ammeter and an ohm meter and the ability to use them correctly.
If you are not familiar with this equipment you would be advised to call a heating specialist.
You could have a weak breaker or a burned out element.
Old 11-19-02, 11:24 AM
charlie856
hi again, ok yes i do know how to use a amp probe, i checked the strips an r good, i just ghanged the breaker an it still trips i don't understand why it keeps triping i changeed all the relays an a new t stat, on this unit the orange wire is going to y term, there is no yellow wire,, also green goes to g, ewhite goes to w2 for heatan red goes to rh which has a jumper wire going to rc,,,PLEASE HELP,,,THANKS AGAIN,,,CHARLIE
Old 11-19-02, 11:47 AM
GregH's Avatar
Super Moderator
charlie856:
There are many possibilities.
A/C connected to same breaker and is trying to start, used breaker and it's weak, bad element that slipped by your test(should probe on a high ohms setting to ground).
How long does it take to trip and what is the amperage when tripping?
SAFETY NOTE: You must not repeatedly reset breaker if it is constanly tripping!
Use the ohmmeter to probe individual circuits after making sure the power is off.
Old 11-20-02, 04:26 AM
charlie856
thanks again,, now can you please tell me how to check a relay to see if its good or bad this unit has 2 relays, ab also how to check if the sequester is good or bad,,thank you,,,charlie,,,
Old 11-20-02, 05:04 AM
charlie856
an also like to know if i jumped the tstat wires w,g, an rh together from the tstat is that safe to do to see if the breaker will teip again n will that turn the heat side on??? t/y charlie
Old 11-20-02, 08:46 AM
GregH's Avatar
Super Moderator
charlie856:
To explain how to test the individual components would be difficult, if you don't have some basic knowlege in electrical troubleshooting. An electric furnace with several sequencers has a mess of wiring in it that could prove difficult to rewire if you have to remove connections to test individual components.
Besides, a short is a technically simpler thing to locate than isolating individual components.
I would suggest a qualified service company do this for you.
Old 11-20-02, 12:08 PM
charlie856
THANK YOU
thanks again, i found the problem, it was one wire that was on the relay i checked all the wires with my meter an found one wire that had a break in it just above the female conector,,you guys are THE BEST THANK YOU ALL AGAIN,,,,,,,CHARLIE,,,,
