Water temp.
Old 11-18-02, 08:56 PM
dddrcz
Post Water temp.
I would like to know what temp my Basmor boiler should be set at. I bought this house two months ago now it getting very cold out. i don't have much heat in my sons room.Is a ranch house there room is at the back of the house. The temp. is set at about 110 degrees. Could that be the trouble.
Old 11-18-02, 09:13 PM
GregH's Avatar
Super Moderator
Received 8 Votes on 8 Posts
dddrcz:
160 deg F would be a good place to start.
Tell us where you live and describe your home and heating system details.
Old 11-18-02, 09:22 PM
dddrcz
Re: water temp
It is a Basmor Boiler serial#2wg3 4-1859 12000Btu/hr AGA 640sg. ft . Crane-Line Basmor made by Bastaian-Morley Co. Inc. in Laporte Indiana. It runs along the floor starts in front of the house along the outsde walls. All the way around the house I have 992sg. ft living space. I live in Elyria,Ohio. It travels about 210ft from start to finish.
Old 11-18-02, 09:33 PM
GregH's Avatar
Super Moderator
dddrcz:
Try the setting I suggested, it may fix you up.
Old 11-18-02, 09:42 PM
dddrcz
Re:water temp
The temp gauge on the boiler is know reading 130 f but the dial ther on the water out let is reading 20 degree higher even before I turn it up this moring.
