Air deflectors
Old 11-19-02, 09:43 AM
tzarriel
Question Air deflectors
I am looking for an air deflector made of metal rather than plastic. I want to use it on my forced air natural gas wall heater to deflect the hot air into the living space instead of the bathroom. Does anyone know where I can get one made of metal? I looked around but only found plastic and it is too hot for plastic.
Old 11-19-02, 11:13 AM
Ed Imeduc's Avatar
heat
Try any of the hvac companys they should have a sheet metal shop and can bend you up something like you want. Or HD and lowes has just small piece of sheet metal that you can get and try and bend it up yourself ED
Old 11-19-02, 06:21 PM
hvac4u's Avatar
too hot for plastic?
what is the outlet temp? gas furnace output generally rated at 30 to 60 degree temp rise, even at 80 degree return output temp should be ok for plastic
