Heat Pump Problem
Electric Heat Pump - RUUD
My heat pump does not cycle. It is running countinuosly even when the indoor temperature is higher than the setting. For a few weeks before this, it was making a 'clacking' sound every few seconds. This sound could be heard at the blower and the compressor unit.
I have a honeywell programmable thermostat. Any insight will be helpful.
Thanks
Thanks
kalroc :
You first can try the off setting on the stat, then if you remove the wires on the thermostat this will tell you if that is the problem. Be sure to shut off the power and mark the wires.
