Electric Heater blows cold air
Old 11-30-02, 02:46 PM
abrowne
My single stage electric heater blows cold air.
I took out the blower fans/motor and checked the resistivity of the heating element which appears to be ok.
It appears that the heating element/coil is not getting power. Any ideas as to what the problem could be?
I put in a new sequencer (last winter), and it worked perfectly all last winter.
thanks for any assistance,
Aaron
Old 11-30-02, 03:03 PM
fjrachel
Check fuses. Check sequencer again. Check circuit breaker if heating elements and blower are different voltages. Make sure you have correct voltage to heat elements.
Old 12-01-02, 06:08 PM
abrowne
Thanks for your help.
Found a burnt wire that was going to the heat coil.
-A
Old 12-03-02, 04:09 PM
fjrachel
Your very welcome...Glad we could help
