make woodburner
Old 12-03-02, 05:54 PM
roland1978
Lightbulb make woodburner
Can any one tell me how are know where I can a how to book or something to tell how to make woodburner? All ideas greatly appreciated.
Old 12-03-02, 06:41 PM
GregH's Avatar
Super Moderator
roland1978:
Take six pieces of steel and weld into a box. Cut a round hole in the top for a chimney and a square hole in the front to put the wood in.
I have seen kits that you can use to turn two 45 gal barrels into a wood burner.
You may find some info if you search the internet.
I've made smaller ones for ice fishing huts and there are a few tricks.
You need to have good welding and fabrication skills because it has to be designed and built to resist warping from the very high heat wood is capable of developing.
Thick steel and bracing is what it usually takes.
Also if you are installing it in anything that is insured I can guarantee the insurance will be void.
