Gas furnace will not click on
Old 12-04-02, 04:41 PM
Dara
Any suggestions on what to check when the thermostat won't click the furnace on???
Old 12-04-02, 04:59 PM
Dara
Is it a 2 zone, 1st or second floor.If 2 zone does your other unit work?
Old 12-04-02, 05:01 PM
hvac4u's Avatar
no heat
does the furnace have power to it? jump red and white at the tstat, if the heat comes on, replace the stat. does the furnace have a flashing light on the circuit board? how about a fuse? may be several things, is the pilot lit if it has one? need much more info
