Blowers fan relay
Old 12-10-02, 07:05 AM
jdcuzmar
Question Blowers fan relay
The blower fan runs constantly even when the unit is in the OFF position on the thermostat. The burner turns ON and OFF properly, so as the condenser unit outside. I have replaced the thermostat and the problem persist.
I was told that the fan relay is stuck closed. How can I test the fan relay?
Old 12-10-02, 04:42 PM
hvac4u's Avatar
testing relay
find the normally open set of points on the relay, ohm them out, if it has continuity, it is bad.
Old 12-11-02, 11:33 AM
jdcuzmar
Unhappy continuity
The normally open set of point on the relay has NO continuity, thus ,Is it OK to rule out the blower fan relay as the cause of my problem?
Please help!
