electric air cleaner
Old 12-10-02, 11:22 AM
Question electric air cleaner
without buying expensive cleaners, what is the best home made solution for cleaning the cells on an electric air cleaner. Thanks in advance for any responses!!
Old 12-10-02, 01:44 PM
Jay11J's Avatar
Get a large wash tub, Fill it with hot water and put the cells in it.. Let is soak for awhile, and take a soft cloth and carfully clean the plates..
Old 12-10-02, 04:15 PM
hvac4u's Avatar
i would use
hot water as jay11j says, probably add some degreaser. rinse well.
Old 12-11-02, 05:31 AM
thanks for your responses guys, I will definetely try that. I have heard of some people that wash the cells by putting them in there dishwasher, what do you think of that good or bad??
Old 12-11-02, 08:13 AM
Jay11J's Avatar
It can go either way.. It all depends on what kind of dishwasher you have.. Very few dishwasher will have the room (with out the tower in the middle... how the tines are set up) Also, if you tink you got it in there, and it falls over and breaks that fine wire in between the cells, then your going to be out of luck then.. and I'd hate to see that happen.. So, just play it safe, and soak it in a deep wash tub.. With this type of system, your going to need to do this every month to keep it at it's peek! I know a fwe people who just gave up on it!! and changed it out to a Media air filter system where some model the filters don't need to be changed out once a year...
Jay
Old 12-11-02, 09:51 PM
jonathanisaac's Avatar
