Gas Furnace not working
Old 12-12-02, 04:30 PM
bigro
Unhappy Gas Furnace not working
I have a 76,000 BTU gas furnace I think is a Honeywell (I only see a name on the thermostat). It has an electronic ignition which means no pilot light to check. Everything has been fine with it until today. When I turn the thermostat up to begin a heating cycle, I can hear a click and a slight humming noise but the burners don't ignite and the fan does not start. I took the cover off and the blower motor is hot. Any suggestions?
Old 12-12-02, 05:14 PM
hvac4u's Avatar
hot motor
not running suggests bad motor although burners should light, at least on occassion if high limit (overtemp from fan not running) trips, as it is auto reset. give more info, leave it off a while, letting it cool down and watch what it does when you turn it back on. let us know
