Hot water heat not working
Old 12-14-02, 06:01 PM
russia01
I have 3 zones in my home with hot water baseboerd heat. When I turn on one of the zones, the baseboards gurgles but they do not heat anywhere in that particular zone. I assume it's probably not the thermostat but would like to know if the most likly cause would be the zone valve or is it possible that something as simple as bleeding the line might be the solution?
Thanks
Old 12-14-02, 06:42 PM
fjrachel
Bleeding the line would be the first step and check the boiler pressure. It should be about 12psi.
