Cold air return
Old 12-16-02, 10:15 AM
Gettinitdone
Cold air return
I've heard from a couple people that if I create a return at the furnace in the basement it will take air down the basement stairs and create more overall circulation in the house. Is this the case? If so, can I just cut a hole in the furnace duct and mount a louver in it?
Old 12-16-02, 10:52 AM
GregH's Avatar
Super Moderator
Received 9 Votes on 9 Posts
Gettinitdone:
Likely not a good idea.
If you do this, you could disrupt air flow to some rooms that are at the end of the air supply.
Unless you have a specific problem to overcome, don't do it.
Old 12-16-02, 06:51 PM
hvac4u's Avatar
return at furnace
this could also rob the furnace of needed combustion air and cause a negative draft on the flue.
Old 12-16-02, 08:32 PM
Jay11J's Avatar
if you are having ductwork problems like the duct popping when the system starts up, and have a sealed burners, then use the return at the return drop...
If you have basement family room, and need to pull the cold air off the floor, then run a pipe to the wall cacity, and put a return vent in the wall in the family room...
