Heat pump clicking
Old 12-18-02, 04:26 PM
tigermetal
Heat pump clicking
I have a Carrier Heat pump with a Honeywell digital thermostat.
Ocasionally my heat pump made clicking sound when it's running(I think the clicking is from the relay on the outside unit, but I can hear it inside too). The clicking sound is synchronized with the "Emergency Heat light" turning On and Off. The clicking goes on for 5 to 10 minutes. Or I can temporarily stop it by lower the thermostat setting. This clicking has been going on for sometime in the winter. During summer months, it runs normal in cooling mode. Can someone tell me what could be wrong ? bad defrost? reversing valve? and why so?? thanks.
Old 12-18-02, 04:32 PM
tigermetal
The clicking rate is about 2 per second
Old 12-18-02, 05:04 PM
KField's Avatar
What model is the thermostat?
Old 12-18-02, 07:12 PM
tigermetal
The thermostat is a Honeywell Chronotherm III
But but the problem is not the thermostat because I swaped it with a new one and the problem remains.
Old 12-18-02, 07:29 PM
KField's Avatar
Swapping the thermostat was a good idea. It was my only bright idea. I'm not familiar with Carriers heat pumps but I'm sure someone will come by here that is.
Old 12-18-02, 08:26 PM
tigermetal
I found a post on another website.... the guy had the exact same problem as I did, he had 2 HVAC contractors checked it. They both said it's a bad defrost board. They both recommend replacing the defrost sensor too. I guess that's something I could try.
Old 12-18-02, 08:37 PM
KField's Avatar
I don't know if that would have to come from Carrier or not. I replaced one on an Armstrong unit last week and it was under $25. Good luck.
