Oil Furnace Question
Obsolete Furnace Part Needed
My sister who lives in North Carolina needs a part for an oil furnace that is obsolete. The furnace was made by TempStar; the burner is Ducayne, DMR-10. The part needed is a head for the burner motor. She believes it is D-1 or DM-1. It is a tiny aluminum ring with a porcelain ring inside. I have several numbers; unfortunately, not sure which numbers go with the furnace and which with the burner. They are: Serial #SB0020518821; Model #NH0C084AH02; Burner #1665440; Serial #N882102253 and Model #867741972.
I realize this is a long shot, but we thought perhaps there is one of these small rings on a shelf somewhere that she could purchase.
Welcome!
Bobbye:
You might want to try the telephone and maybe someone has a furnace graveyard somewhere.
It may be possible to just replace the burner assembly if you can't find the piece.
Did you try a search on Google?
Good luck with your hunt.
I have a listing for a D-1 Endcone. Ducanes part # is B4152552. The supplier will not sell to the public but you could have a local heating dealer get it for you. The wholesaler is R.E. Michel and their part number is 7H707 and it is under $30. Find a local heating contractor who has an account with them and ask them to order it for you.
Thanks For Your Suggestions
Thanks very much for the help in locating the furnace part. My sister found the part with CC Dickson Co. as one of you suggested. The part numbers another suggested were helpful in determining what was needed also. We think it is the right one and it is worth trying. Thanks to all.
