Automatic Damper on a Smith Gas Boiler
Anybody know offhand if the auto damper closes for both thermostat and ventilation problem triggers?
I ask because in the latest freeze, the boiler has had a a hard time keeping the house over 60 degrees. We usually keep the therm. set at 64 or so which is comfortable, it hasn't made it that far in a few days. 59 is about as far as it gets.
Ventilation seems clear enough .. but I noticed that when boiler shuts off, auto damper closes. Im just not sure if this is an indication of ventilation problem, or normal behavior. If it's normal, maybe I have a dying thermostat?
TIA
TIA
daca:
In order to provide you with a good answer we need to know more about your system.
ie: Water temp and pressure, zones, fuel etc.
If you read the anouncement at the top of the Heating and Cooling forum - Read B-4 Posting, what we need to know is there.
