Extending ducts
Old 01-27-03, 01:09 PM
brewhill
Extending ducts
I'm planning on drywalling one side of my house which is currently plaster directly over brick. However, I have ducts which are flush with the plaster walls.
What is the easiest and cheapest way to extend these ducts to make them flush with the new walls?
Old 01-27-03, 01:39 PM
Ed Imeduc's Avatar
duct work
Do you mean in the wall and up?? Can you use the reg. 3 1/4" x 10" or what?? There is a basboard register could you use it? could you just add studs to the wall and then drywall? Need more info here ED
Old 01-27-03, 01:48 PM
brewhill
Extending ducts
I'm sorry that my last post wasn't very clear. My plan is to attach firring strips to the wall then hang drywall.
I'm unfamiliar with ductwork and I thought that I would have to extend the ducts further into the room between the existing ducts and the new register. Do I need to do this and if so how?
The current register is about 1' off the floor so I'm not sure if I can use baseboard registers or not.
Old 01-27-03, 02:00 PM
Ed Imeduc's Avatar
duct work
Ok do you have what we call a wall reg like a 10"x6" or 12"x6" if so you can just get a short piece of duct the size and add it on to them??? If Im right in what you have.Also yes you have to do this as it is a heat out let and it has to be in metal duct to the reg. ED
Old 01-27-03, 02:06 PM
brewhill
Extending ducts
You are correct, I have a wall register about 10x6.
Thanks for your help!
