bleeding of basebord hot water heating system
Old 01-29-03, 10:41 AM
suprma2333
Exclamation bleeding of basebord hot water heating system
can some one please explain the proper way to blled a closed baseboard hot water system i know it must be done at the furnace by the circulators which i have two of for a two zone system.need to know the proper wy to bleed each zone.thankyou
Old 01-29-03, 02:05 PM
KField's Avatar
Check this first
Before I go into the long version, can you see if you have small vents at one end or the other of your baseboard heaters? They will be under the end cap but you can probably see them with a flashlight. Please look there and let us know. If not you will need the 'how to purge a hydronic system' lesson instead of the 'how to bleed a hydronic system' lesson.
