furnace
Old 01-29-03, 06:20 PM
jpbrevin
Question furnace
My furnace has, as of late, been shuting off because of the pilot. I have manually lit the pilot to restart. What can I do resolve this?
Old 01-30-03, 07:39 AM
bigjohn
It sounds like you mean a standing pilot? #1 problem with those systems is the thremocouple wears out and doesn't produce sufficient voltage to keep the safety relay in the gas valve pulled in. #2 problem is the pilot burner air slots and/or the gas orifice in the pilot burner are dirty/corroded which results in an insufficianet pilot flame and has the same effect as #1. You can try replacing just the thermocouple [cheap] and see if that restores operation. I usually replace both the thermocouple and the pilot burner assembly because I have to warranty my work.
Old 01-31-03, 04:37 PM
hvac4u's Avatar
also look
to see if 2 wires attach to the base of the thermocouple, if so it could be a safety opening up. i am with bigjohn, change the tcouple first.
