Charging a Heatpump
Old 01-31-03, 05:33 PM
cuffs054
Charging a Heatpump
Bouncing around the questions, I came across one relating to recharging and/or adding freon to heat pump in winter. I never gave it much thought, but does the outdoor temp effect how you would do this? Growing up in FL I guess it's not much of an issue, but I wondered about further north. What does happen in a really cold climate?
Old 01-31-03, 06:11 PM
hvac4u's Avatar
H/P charging
very tricky is cold weather, easy to overcharge, as the cold o/d unit (evap) can hold a lot of refrigerant. most pros will go back in warmer weather to balance charge. some units have a charging chart inside the unit, many are charged to proper discharge line temp.
