Afue?
Old oil furnace efficiency?
I am replacing my old oil furnace. Its a 1970s model Armstrong L61-112 (112K BTU/hr) unit. Anyone have an idea of how efficient that was rated at? I am just wondering what the efficiencies were back in the ole' days. Peace: e3 - spamman
Edit:
I changed the title of the thread to more accurately describe your question.
Edit:
I am assuming the 400d (example) is 400 degrees faranheit? I would need a thermocouple huh? I am not sure what the CO2 level is, but it should be logged on the furnace from his visit last week. I am getting really annoyed with this oily smell. But get this.... NO visible smoke on anything on any level of the house. They said there is a crack in the heat exchanger but I would assum to see some smoke on the white wall registers or on the light colored walls. nothing. e3
CO2=carbon dioxide and you'll need a thermometer to measure stack(flue) exhaust temperature and check for smoke where flue exits house, not registers in the house. Yes, fahrenheit.
I doubt a CO2 test was done on your unit. Most techs who do that type of test would not have left you with the smell problem.
Received 1 Upvote
1 Post
oil burner
MY 2 cents.Old oil furnaces , if you set them right with a combustion testing kit we could set them at about 70% to 80% most of the time.You need the kit so you can set the draft , take the co2and then the temp.Do you still have that crack in the heat exchanger?????You can run the furnace some to warm it up then put in a small smoke pill and see if you get and smoke up in the home. Id do this to make sure there is no leaks in the furnce ED
Unfortunately, the mid 70s wasn't the old days. Unless your burner has a 1725 rpm burner motor on it, it isn't much different that the new one you will get. If you have a flame retention burner, preferably a Beckett, you have the same unit you will be getting. No changes in burner technology have happened since the mid-late 70s. Sorry. The same holds true for heat exchangers. No different now than then. I hope you are not buying a new furnace to save money on fuel because it won't happen. Many advertisements say "call now to get a new furnace and save up to 15% on your fuel bill". What that really means is if you have a real dinosaur piece of crap, we can save you 5%. If the promise came with a guarantee, you would see a very different advertisement.
