weather king
Old 02-02-03, 06:36 PM
lakegod94
Unhappy weather king
I have a weather king heater the piolt light is on and I can get the fan come on by setting the thermostat to the fan on postion but the burners will not come on. I changed the thermostat and clean everything. It is a standing piolt. when I unscrew the thermocoupling the piolt will tur of but I am not sure if that means it is good. Could anyone help.
Old 02-02-03, 08:21 PM
GregH's Avatar
Super Moderator
Received 8 Votes on 8 Posts
lakegod94:
If you remove the thermostat and jumper the R and W terminal that will tell you if it's the thermostat.
If that doesn't do it you will need to use a voltmeter to test the transformer and then check if there is 24 volts to the gas valve.
It's not likely if you have a fan relay, but it is also possible that you have a millivolt system which does not have a transformer.
Look around and tell us what you've got.
