Heater Ignition Problem
Old 02-08-03, 01:34 PM
pjtessy
Heater fan runs but igniter doesn't lite or glow.
Fan will run forever until I turn thermostat down.
Blower is not running at all as it doesn't run unless there is ignition.
How can I tell if the igniter is bad?
I bypassed the vent pressure switch by sucking into the hose myself.
I disconnected the sensor lead to the module but still did not ignite the pilot light.
Could it be the roll -out switch?
HELP!!!!!!!!
Old 02-08-03, 01:45 PM
fjrachel
You'll need to ohm out the ignitor with a meter.
Old 02-08-03, 02:33 PM
pjtessy
I know it's not recommended but I was considering kighting it by hand to see if it was getting propane to it.
Thanks
Old 02-08-03, 03:33 PM
hvac4u's Avatar
NO !!!!!!!
especially if it is propane.....do not do it!!!! is the ignitor getting voltage? if you cannot tell PLEASE call a pro!!!!
