heat pump system problems
Old 02-10-03, 07:23 AM
rlk123go
Angry heat pump system problems
yes when i have my heat on it dosnt work unless it is set on 80 degree's& when i use the cooling cycle it doesnt work unless i set the temp at 55 HELP!!
Old 02-10-03, 01:43 PM
hvac4u's Avatar
heat pump
when you say the heat will not work until you set it to 80, does the outside unit run before then, how about in cooling, does the conpressor run when set at 60? the tstat may be bad. how far south of atlanta is mcdonough? i can have somebody there this afternoon! seriously, give a little more info, we can walk you through it.
