blower won't shutoff
Old 03-30-03, 07:26 AM
metx
i have a bryant hot air furnance. the burners won't go on i'm in the process of changing the electronic igniter. but my blower does not shut off if i shut the thermostat it only shuts off when i shut the switch on the furnance. could that problem be part of the electronic igniter or the limit switch any other suggestions. i have experience working on hot water and steam systems at work but this is my own home .thank you. P.S. does anyone know where i could get a bryant trouble shooting guide.
Old 03-30-03, 07:56 AM
fjrachel
Sounds like an open limit switch
Old 03-30-03, 08:17 AM
hvac4u's Avatar
i agree
check all limit switches, may be one in the blower as well as any roll outs that could be tripped
Old 03-30-03, 08:49 AM
metx
i think i found the limit switch is it a little black cover an 2 wire connect to it it looks like a thermostate probe with a small silver dail the size of a dime connecting it ?
Old 03-30-03, 09:18 AM
hvac4u's Avatar
sounds like it
where is it located? can you ohm it out?
Old 03-30-03, 11:32 AM
firsthvac
A little more info here would be better before getting into what the problem might be since it could be a relay or a fan switch as well.
Do you have a/c that uses the furnace blower?
Do you mean when you turn the thermostat switch to "off" or when you turn the thermostat to it's lowest setting?
Does the furnace light up when you set the thermostat switch to "heat" and turn it up all the way?
Is the thermostat fan switch in the "auto" or the "on" position?
Let's not guess at the problem and get tx off on a wild goose chase, we're better than that.
Old 03-30-03, 11:38 AM
hvac4u's Avatar
NO HEAT
still sounds like an open limit
Old 03-31-03, 05:40 AM
metx
i found the problem it was the vccc switch thank s to everybody for the help
