What two-stage thermostat to use?
Old 04-02-03, 01:04 PM
ct287
Question What two-stage thermostat to use?
Need to replace an old manual Lennox two-stage thermostat that is only used for AC. What do you use for your two-stage cooling system (not heat pump)? Is the $150 Honeywell T8624D Chronotherm IV Deluxe worth the price? You can get a digital single-stage thermostat for $15 at HD. Why two-stage thermostat is much more expensive? Thanks in advance.
Old 04-02-03, 01:44 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
tstat
Do you know for sure you have a 2 stage set up on your AC units or need one??Or does it control 2 AC units?I dont think you need that old chronotherm. Need more info on the unit or units you have ED
Old 04-02-03, 01:58 PM
GregH's Avatar
Super Moderator
Received 68 Upvotes on 62 Posts
Is this thermostat used in a commercial setting?
Old 04-02-03, 02:38 PM
KField's Avatar
Check it out again. Typically when a thermostat says it is 2 stage they are referring to heat. Heat pumps are 2 stage (and popular) but in heating mose only. But as the boys are implying, 2 stages of cooling are rare in residential installations.
Ken
Old 04-02-03, 03:46 PM
ct287
It is a two-speed compressor
there is an extra wire for turn on the high speed when it's hot enough. It is a Lennox residential system.
Old 04-02-03, 03:56 PM
KField's Avatar
I'll be darned
Sounds like you will need to match that 2 stage cool. That could elevate the price of a replacement. Sorry to doubt your knowledge of your requirements.
Old 04-02-03, 05:27 PM
GregH's Avatar
Super Moderator
ct287:
Even though you have a residential unit you are in the realm of a commercial thermostat and unfortunately have to pay the price.
