Duct Vents for Summer and Winter
Old 04-04-03, 07:52 AM
goindimon's Avatar
I have a easy question regarding whether the duct vent should be open or close for the summer/winter. There is also a humidifier involved. Thanks
Old 04-04-03, 10:02 AM
Ed Imeduc's Avatar
vents
Id say let it be ,let it be. If the system worked fine. You dont say AC or not. You might want to turn off the water to the humidifier. ED
Old 04-04-03, 05:22 PM
goindimon's Avatar
I think you misinterpreted my question. All I want to know is whether to have the vent for the blower open (on) or closed (off) for the summer.
Old 04-04-03, 06:19 PM
KField's Avatar
If you are referring to the damper on the duct of a bypass type humidifier, it is usually closed in the summer because you do not want any extra humidity and you need all the airflow that your blower can produce.
If you meant another damper, describe its location to us and we'll try again.
Old 04-04-03, 08:19 PM
goindimon's Avatar
Thanks
That's the one, now I know it's called a damper.Thanks
Old 04-05-03, 09:46 AM
Ed Imeduc's Avatar
Lightbulb vents
Hey you Got IT KFeld the right----- INFO------ sure helps
What do I do with this watchamucallit dont help
Id shut the water off to it also ED
