Air Conditioning
Old 04-28-03, 06:43 AM
janet cuthbert
Question Air Conditioning
What is the formula for measuring a room or area for an air conditioning unit - we need to measure square feet to arrive at a btu - is it room height x width x length?
Old 04-28-03, 07:47 AM
firsthvac
Dear Janet--
Using sq. footage is a rough method for estimating btu's needed for a room or home as it does not take into account type of construction, hidden btu's from other sources, etc. A load calculation is always best to make sure you don't oversize or undersize the a/c for proper airflow and humidity removal.
Spending a few extra bucks now for the calculation can save you hundreds in operating and repair costs in the future.
Nonetheless, here is the rule of thumb:
For heavy insulated areas use,
length x width divided by 400 x 12,000= approx. btu's of cooling needed
For light-medium insulated areas use,
length x width divided by 450= x 12,000= approx. btu's of cooling needed
