replacement heat pump
Old 04-28-03, 11:22 AM
mstillmc
i have a trane system but only need to replace the heat pump, how can i compare other brands for replacement heat pumps to work with my indoor system?
Old 04-28-03, 01:58 PM
mattison's Avatar
If this is an older system you are replacing, the new outdoor unit will probly require differant size linesets and any time you replace the outdoor unit you should replace the indoor coil that matches the new unit.
Old 04-28-03, 05:57 PM
hvac4u's Avatar
heat pump
you do not say how old the AHU (inside blower unit) is, it must be matched capacity wise to the other component, if older than say, 7 years, replace it as well for top efficiency and reliability. other than that, any brand for the most part will work, low voltage controls must be changed if reversing valve is energized in heat (rheem/ruud etc)
Old 04-28-03, 06:33 PM
H
Received 1 Vote on 1 Post
Trane
Stick with Trane or American Standard....Do you keep your cars as long as you do your heat pump??? It runs 24/7.... think about it! ....and compare the maintenance records.....I think they should start to put hour meters on them...
