Non-standard Rangehood duct?
Old 05-07-03, 10:30 AM
Paul
Looking for a non-standard? rangehood duct that goes from 10"x3.75" to a 4" round at a 90degree angle.
At HomeDepot there is something similar that goes to a 6"round and there is a 6" to 4" reducer available, but the cabinet depth is too shallow.
HD also has a 10" x 3.75" to 4" round STRAIGHT fitting to which I could attach a 90degree 4"round, but not enough height in cabinet to do that either.
Is such a duct fitting available anywhere or would a sheet metal guy be able to knock one out for me fairly easily?
Old 05-07-03, 12:22 PM
Ed Imeduc's Avatar
duct work
Any good tin bender can just make you one up. Why do you want to cut it down to a 4" ?????? A vent fan with a 3 1/4" X10" should have a 6" round vent pipe. You could also put a 3 1/4"x10" stack on the fan, cap it and cut the 4" round out the side of it. or there is the 3 1/4"X10" boot 90 d you could use amd put a 4" reducer in it or cap it and come out with the 4" pipe???????? ED
Old 05-07-03, 06:12 PM
hvac4u's Avatar
very common here in georgia
what you describe i would call a 4X10 90 degree to a 4" round boot, local hvac supply houses have bins full.
Old 05-08-03, 06:34 AM
Paul
HVAC Supply House came through
HVAC4U,
Thanks for the advice. I did find a supply house in Chicago that had the "4 x 10 90 to a 4" round boot" as a stock item. Then he crimped the 4" round for me in about a minute at no extra charge.
Ed, I know the rangehood should duct to a 6" round, but had to go with what I had coming out of the wall. There was too much going on in the raceway to accommodate a 6" duct. Good suggestion on the stack and coming out the side. But when the stock item was available, hey, gotta go for it!
Thanks for your prompt replies guys.
