centeral-air cond.
Old 05-09-03, 11:01 AM
chet19472000
centeral-air cond.
why is it that my condensor fon motor (above the compressor) shut off after it run for a while ,compressor still runs ,but gets very warm on the cooling fins i know the condensor fan cools the compressor, can't figure out why fan stops , ty vm a frustraded man lol
Old 05-09-03, 02:26 PM
KField's Avatar
It may have a bad capacitor and go off on high temperature. With power off, try to spin it to see if it is free. If it spins easily, get the capactor checked.
Ken
Old 05-09-03, 03:06 PM
chet19472000
condensor fan motor (kfield)
i would like too thank you for your insight on my problem with condensor fan motor ,after i left sending you the message i went back out side to relook at the problem and noticed that motor had a oil fill on it it sits vertical ,so i took fan blade off and oil cap and oiled it very well, reassambled and started comp. again r.p.m.'s went a lot faster now , it's been an 1 hr and still running well . i can't ty enought , for your info. on my problem, and i will get the capactor check. ty again for a job well done. chet19472000
