air flow
Old 05-10-03, 06:13 AM
jeepers
air flow
Last year I had my system charged. Inside coil was freezing-up.
Current problem is in output at vent.
1- Air is cold.
2- Air flow seems to be restricted, but no freezing etc...
My question is this.
Where should I start checking?
****I have already checked the inside coil and replaaced the filter.
Old 05-10-03, 07:27 AM
firsthvac
hi jeepers--
Sorry but you're not making any sense here. What is the problem you having...no cooling...a room too hot...thermostat not shutting?
Please read the first post listed in this forum and then return here to give us MORE DETAILED INFORMATION.
thanks
Old 05-10-03, 08:43 AM
jeepers
Some of the vents are not emitting as much volume of air as they should.
True, I have not measured the volume, but when the fan is engaged some vents have a lot of air and some you barely feel.
