Heat when A/C not blowing
Old 05-10-03, 07:40 PM
NWA
Unhappy Heat when A/C not blowing
We have an electric heat pump. Now that the weather is warm, we set the heat setting down as far as possible (55), and the cool setting at about 75. Our problem is that when it is not blowing the cool air, a little bit of hot air is coming through the vents, most noticibly one one side of the house. Any idea what the problem could be? Thanks for the help!
Old 05-11-03, 07:17 AM
GregH's Avatar
Super Moderator
Received 35 Votes on 33 Posts
Question More info please.
Touchdown:
Could be a bad reversing valve, bad relay, faulty emergency heat strips if you have them...................
You havn't given us anything to go on if you want some advice on locating the problem.
Read this and give us more to go on.:
http://forum.doityourself.com/showth...hreadid=122673
Also take the temperature of the air as it's coming out of the register, preferibly close to the furnace, throughout the cycle.
