Window Unit?
Old 05-14-03, 12:08 PM
ray98362
Window Unit?
I live in an apartment and have casement (slider type) windows.
Can I install a regular window type unit or do I really need to buy the casement type that typically runs 3X the price of a small window unit.
Also, could a standard unit be installed on it's side or would it need to be in the normal orientation
Old 05-14-03, 01:54 PM
hvac4u's Avatar
sorry
from what i understand you describe, tall thin opening, must get a dedicted unit. cannot put a standard one in on it's side
Old 05-14-03, 02:07 PM
ray98362
hmmm
well, the window's plenty wide enuff, maybe I'll just put it on a board or something... long as I block off the top of the opening I guess it would work
Old 05-14-03, 02:38 PM
Jay11J's Avatar
Ray,
There is no reason why you can't do it as long the window is wide enough to fit the A/C unit into it....
Only down fall is your going to have a bigger piece of plywood to fill in the rest of the window. So that will let in less light into the room..
