A/C leak
Old 06-05-03, 08:29 AM
Jodi
Unhappy A/C leak
I have a Rheem model #RCBA2459As14. The unit is draining a little out the pipe outside and draining a lot on my floor under the unit inside. It seems to me that the drain is clogged. How do I get to the drain inside at the unit to put bleach in it? I do not see how to take the unit apart. Is this something for a service person to do?
Old 06-05-03, 11:13 AM
mattison's Avatar
If you or someone you know has a shop vac you can usually suck the line clean.
Old 06-06-03, 08:17 AM
Jodi
Thumbs up thank you
The shop vac did it, thank you.
