Window AC weaK
Old 06-08-03, 04:49 PM
wasmeneh
Angry Window AC weaK
Bought a new little get-a-way house has a window unit that is supposed to cool 3 rooms (whole house is 1350 sft) seems to be blowing slightly cool air I suppose it needs more freon.... whats my next step.
Thanks Mike
Old 06-09-03, 06:06 AM
54regcab's Avatar
Freon leak
Unfortunately a window unit is a sealed system, to add service valves and charge the system would exceed the cost of a new window unit in most cases.
Funny thing is they put the pressures on the sticker but have no means of checking them ...
Old 06-09-03, 09:28 AM
hvac4u's Avatar
i would
take it out and clean it thoroughly with a high pressure hose, keeping water out of the electrical components. many tech have taken them to the car wash. failing that, a BPV or bullet piercing valve will attach to the line and allow access to the system.
Old 06-10-03, 08:56 PM
firsthvac
Since you don't give any information about the unit itself (model number, location of the unit, etc.) or the environment it is running in (indoor/outdoor temperatures, temperature coming out of the unit, etc) you could have problems ranging from an undersized/overworked unit to a failing compressor to a lack of airflow and so on.
Follow HVAC4U's advice on cleaning the unit. If you get no improvement, replace the unit...it'll cost less than finding out what's wrong with it.
