Charging AC Unit
Old 06-09-03, 06:18 PM
p6texas
Question Charging AC Unit
Is it possible to add freon to an outside unit without the use of gauges? Knowing very little about HVAC systems, is the freon added to the liguid or the gas side?
Old 06-10-03, 05:12 AM
Thomas W.
Don't even try it, the unit gets charged based on temperature and pressure readings. If it is not done correctly you may be buying a new unit.
Over charging will cause just as many problems as under charging. You have to have more than just guages.
Old 06-10-03, 06:18 AM
GregH's Avatar
Super Moderator
Upvotes Received: 5
p6texas:
A/C sealed system repair is no longer a diy activity due to environmental and licensing concerns.
Old 06-13-03, 12:51 PM
p6texas
Actually after reading some of the other postings, we decided to bite the bullet and replace the inside unit. Does anyone no anything about Copeland upright airhandler units? This is the unit that our AC guy recommends for our house.
Old 06-13-03, 12:57 PM
Thomas W.
That is a builder grade unit,( cheaper models) if you plan to stay in the house awhile I would put in a name brand unit.
Those have been known to have problems, like freon leaks after 4 or 5 years.
Old 06-13-03, 03:29 PM
GregH's Avatar
Super Moderator
Upvotes Received: 5
p6texas:
I didn't know Copeland made an air handler.
Could you be referring to an air handler with a Copeland Scroll compressor in it?
Old 06-13-03, 06:53 PM
p6texas
Ok, Thanks for the info. My wife stated that the name may have been Goodman instead of Copeland. Does that make any difference? We are planning to put this house on the market very soon.
Old 06-13-03, 07:01 PM
hvac4u's Avatar
putting it on the market
then go ahead and put in the goodman, a very low end unit.
