checking charge
Old 06-10-03, 12:13 PM
checking charge
I've studied some of the online info about checking charge via the temperatures and pressures and charts, superheat, etc. When checking the temperature with the digital thermometer, do you take the reading just outside the outdoor unit or near the evaporator for the high and low side. Also, what is a good way to attach the probe to the lines to assure an accurate reading.
Old 06-10-03, 12:38 PM
hvac4u's Avatar
superheat
i attach my probe under the armaflex at the outdoor unit. a zip tie holds it tight to the line for a good contact
