lines are freezing up on my central air
Old 06-13-03, 12:43 PM
oneofthechozen1
line coming into house are freezing up causing air conditioner to not work at all what can i do other than letting it defrost.
Old 06-13-03, 01:01 PM
Thomas W.
It is low on freon( has a leak) or you have a restriction in the air flow. make sure your filter is clean.
It will keep freezing up again and again you have to check it.
I would call a service company if you leave it that way to long it will cause the compressor to burn out.
Old 06-13-03, 01:16 PM
oneofthechozen1
thank you i should have checked the other posts closer
