ac size
Old 06-18-03, 05:28 PM
New Member
ac size
Can anyone tell me how big a air condioner unit is needed to cool a house in Minnesota tha is 2400 sq.feet,split entry,good insulation,7 rooms.The indoor coil will go in a 70,000 BTU oil fired furnace.Is here any more info needed? Thanks very much.
Old 06-18-03, 10:31 PM
GregH's Avatar
Super Moderator
Received 9 Votes on 9 Posts
mark7:
I'm afraid you've come to the wrong place with your question.
There are too many other variables to consider to be able to come up with a good answer.
I would suggest you get several contractors in to quote you on this and ask for a detailed load calculation.
They will also determine if your existing blower and ductwork can handle the required cooling capacity.
Old 06-19-03, 05:21 AM
yes, get a few quotes. my house is similar to yours in upstate ny and i have a 2.5 or 3 ton unit. it should take a person about 30 minutes to determine the size..... they need to measure the home and look at some of the duct work.
Old 06-19-03, 07:46 AM
hvac4u's Avatar
you can
download the program yourself. go to www.hvac-talk.com and click on it at the top. @$40
Old 06-20-03, 05:26 PM
54regcab's Avatar
Actually he bumped the price to $49.00
