AC Lines freezing up. What causes this to happen? Also no cold air.
I am having my lines from A coil to condensor unit freeze up and am getting no cooling form the unit. What is the reason for this and what is the rememdy?
1st verify the indoor blower is running. Could be as simple as dirty filter, check and replace. Could be blocked return vents, uncover them. Other than that it may be low on refrigerant or some other mechanical malfunction which you'll need to call HVAC co. for.
Let us know what you find "details"
