Coil leaking on heat pump?
Service man came out today and said my coil on my heat pump is leaking and needs to be replaced. The estimate he gave me is $800 to do the job. This seems a little high to me. What should something like this cost?
sounds reasonable
be sure it matches the one taken out....will need to be OEM part if it is in an airhandler as opposed to dual fuel setup. this is fair for sure, those things are not cheap
